Viewing/Editing History of nx prt file?
Hello there
I had created a nx 6 assembly and parts last year and would like to view the history and change/update it to being created this year without having to redo all the parts and assembly.
Is there any way of doing so for the prt files?
Is there a program to do this or can this be done in nx
Thanks for all the help
RE: Viewing/Editing History of nx prt file?
Information -> Part -> Modifications...
...where you will get a complete history of all of the save dates as well as who saved the file and on what system. There will also be a list of edits/modifications made to the file with a references to the relevant 'file save' record. Sometimes the information displayed may appear a bit cryptic but it does try to indicate the types of edits/modifications made and if it were parametric changes those are recorded. It also will show when and who made the changes by looking back at the referenced 'file save' record.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
By going to Information -> Part -> Modifications...
I am only able to view the part history, But I am unable to edit/delete info from there
So how would I be able to clear the part modification history without changing any of the parameters. I would like it to not show that it was created last year. How can this be done?
I just want it to show that it was created this year.. is there a way by exporting it to a new file/copying only the geometry .... rather than working on the whole assembly or part from scratch. If so what is the procedure?
Thanks for the help
File -> Export -> Part...
...and select the 'Part Specification' option of 'New' and then select the 'Specify Part' button and enter a new part file name (do NOT use the 'Existing' option for this particular task). Now select the 'Class Selection' button and choose the 'Select All' option and hit OK. The rest of the settings, except for the 'Remove Parameters' option which you would of course NOT select, will probably have little or no effect if your part is not an Assembly nor are there any WAVE links in it. Now just hit OK and then open your newly created Part file and note that the ONLY 'history' will be a single entry for TODAY.
John R. Baker, P.E.
Industry Sector
Cypress, CA
That was exactly what I was looking for.
But I am not able to do it for a whole assembly. For a whole assembly how would I do it?
Please and thank you
Very greatfull to your quick response :)
John R. Baker, P.E.
Industry Sector
Cypress, CA
Really appreciate the feed back
And I completely understand what you mean...
Another question.. Is the site
http://www.plmworld.org/museum/ Created/run by you?
John R. Baker, P.E.
Industry Sector
Cypress, CA
A job well done!!
Outstanding Collection of info!!
So your not the curator anymore, how come...
John R. Baker, P.E.
Industry Sector
Cypress, CA
