SPR 333035 - Updates?
Hi All,
Does anyone know if there has been a fix for this yet? This is in regards to opening an assembly and getting an error message about rolled back features, do you want to roll them forward.
I have a large assembly that this happens everytime I open it.
SW2010 SP4.0
SW2010 SP4.0
RE: SPR 333035 - Updates?
This is a known issue, and a workaround exists to resolve the issue.
1. Go to Window > Close all, and save all files when prompted.
2. Reopen these files and they will work properly. <However, there should be no rebuild message when re-open the assembly file according to the message before saving it.>
This issue has been identified and reported to the development team on SPR 333035 ("Rollback and adding cut feature of component result in Non-responsive status of its assembly.")
Please refer to the SPR look-up facility on the SolidWorks website to verify the current status of this SPR.
(http:/
Please contact your reseller in order to be added to the notification list so that you are informed when the issue is resolved.
So, no, it hasn't been resolved as of yet. You should contact your reseller to be added to the list to be informed.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
