torsion in a plastic cyinder ansys
i am using ANSYS, and i am appliying torsion in a cylinder, i am using solid72 or solid73 element because is the only solid that let me apply torsion, (ROTZ, degree of freedom), the problem i have, is that i can not get a plastic behavior of the material, it always behave as a elastic material, im using inelastic, rate independant, isotropic hardening, mises plasticity, bilinear, tang mod 0.
any suggestion,
any suggestion,
RE: torsion in a plastic cyinder ansys
Also you might find this forum helpful..
http://www.eng-tips.com/threadminder.cfm?pid=569
