Best industrial label adhesive/material combo for nylon (polyamide) 66
Hi...I seek the best label material and adhesive combo to "stick" to the surface of a molded nylon 66 connector housing. The housing surface is round (diameter of 34mm), with a height of 21mm. The surface is not flat, but is curved (R15.75).
The label will experience seasonal temperature fluctuations (max) of -50'C to +60'C. The label will be exposed to UV and rain/sleet/snow as it is to be used outdoors. Also, the label will be exposed to vapors and dust that one would typically associate with an oil refining facility.
Many thanks in advance for any assistance that you could provide...cheers!
RE: Best industrial label adhesive/material combo for nylon (polyamide) 66
Some manufacturers may claim that they have something that can. They will be lying.
Embossed, engraved or laser etched stainless is your best option.
We used a ceramic on SS to identify lines for UT survey in a very hostile environment.
http://www.idplate.com/
TTFN
