Practicality of composite wood-concrete floor systems
Assuming that one could actually design it to work, how practical do you think a composite wood-concrete floor system would be? It would be a precast conc. slab with a perforated, embedded T shape with the stem sticking out. A glulam beam would then be ripped with a grove to receive the stem, which would be glued in.
Assuming all this could calc out to work, and somehow the wood would be protected from the concrete. How practical is this over just using a thicker precast slab or a composite steel-concrete floor? I know it is a very general question, but it isn't for a specific building.
RE: Practicality of composite wood-concrete floor systems
Kieran
