Executing code in a Mapkey
Good morning,
I've been reading over the threads to learn more about using a mapkey to do repetitive operations in pro/e. I would like to create a code to print every drawing that is called out in an assembly drawing. I've got the basic recording of a mapkey figured out, but now that I have that i need to add some code to it to begin a loop. How do I add code (vb) to the mapkey function?
Thanks in advance!
Thanks in advance!
