Exceeding PV limit of a plain bearing
What if I exceed the recommended PV value of a bearing? Does it become useless (break, gall or seize) rapidly, or does only its life shortens?
And when these PV values are determined, are the manufacturers stick to any standard of ISO, ASTM...?
Thx
Thx
RE: Exceeding PV limit of a plain bearing
You may be able to exceed the limits by very carefully selecting your lubricant, cooling and filtering it as well as getting your tolerances and clearances perfect.
I am, actually, trying to understand what is this "PV" thing analogous in strength of materials; the yield strength or the endurance limit of fatigue concept?
The V part is a velocity, of course.
The P part is a pressure computed on the projected area of the bearing, and the allowable pressure is usually orders of magnitude lower than the compressive yield stress.
What happens to a given bearing material at PV values above the limit depends to a large extent on whether the P is excessive or the V is excessive. I.e., the resulting failure modes are usually different for each bearing material, and they are different from one bearing material to another.
That said, the usual result of excessive V is, as noted, heat, and damage normally associated with overtemperature of the particular bearing material.
The usual result of excessive P (still nowhere near the yield stress, mind you) is extreme wear, not necessarily accompanied by plastic distortion.
I am troubled because you appear to be contemplating intentional use of some material beyond its recommended PV value. That's just a waste of money and time.
The recommendations are based on experience. If you do not value experience now, you will, after you have ignored it and then acquired it for yourself.
Mike Halloran
Pembroke Pines, FL, USA
