lego like press fit injection mold design
Hello I'm trying to learn injection mold design.  I've done 3 molds so far with good success.  The next two pieces I want to make will mate together.  I want to use a pressure fit where the parts can be attached and detached easily exactly like two lego pieces.  What are the specs on a basic lego piece to allow for the fit?  How many thousands larger is the male cylinder in relation to the female hole?  Any help would be greatly appreciated!
RE: lego like press fit injection mold design
Legos don't mate cylinder to hole.
They mate cylinder to array of hollow cylinders, tangent circle to tangent circle with a little interference.
.. which makes the tolerances somewhat easier to hold, but I don't know what they are, exactly.
It's time for you to buy some Legos to measure.
Mike Halloran
Pembroke Pines, FL, USA
Got a lego piece and you are definitely correct.  I'm having a hard time measuring with my calipers looks like maybe a thousandth?  Maybe I'll try sanding off the fillets and then flat bed scanning the piece.  Anyone have any insight?
