Structural systems
Structural systems
I'm designing 4pcs-4m long steel column using wide flange rested on a reinforced concrete slab 127mm thk. with 500mmx500mmx20mm thk. base plate. Is this possible to carry a certain load without cracking the outermost fiber of the slab due to axial load and bending on both direction?
RE: Structural systems
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
