The command "SelectRecord" isn't available now HELP!
Hello all,
I'm having a really irritating problem and I haven't been able to find a solution anywhere on the web.   I'm using Access 2003 and I have a form thats controls are bound to a simple table.
I created a "duplicate record" button using the wizard, and then tweaked the code just a little bit in my attempts to fix the problem:
Private Sub btn_Duplicate_Click()
On Error GoTo Err_btn_Duplicate_Click
    If Me.Dirty Then DoCmd.RunCommand acCmdSaveRecord
    'Duplicate the record
    DoCmd.DoMenuItem acFormBar, acEditMenu, 8, , acMenuVer70
    DoCmd.DoMenuItem acFormBar, acEditMenu, 2, , acMenuVer70
    DoCmd.DoMenuItem acFormBar, acEditMenu, 5, , acMenuVer70 'Paste Append
    'Focus on the Scenario ID, it needs to be changed to make the record unique
    Forms![frm_LOPA_Master].[Scenario_ID].SetFocus
Exit_btn_Duplicate_Click:
    Exit Sub
Err_btn_Duplicate_Click:
    MsgBox Err.Description
    Resume Exit_btn_Duplicate_Click
End Sub
The code used to work correclty, but at some point I made some changes to the form properties, other control properties, or something else messed things up.   When I click the "Duplicate Record" button, Access creates a new record, but none of original records values are carried over.  No errors are trapped.
If I put a break in the code and then step through, an error is trapped at the line: "DoCmd.DoMenuItem acFormBar, acEditMenu, 8, , acMenuVer70".   The error message is:
I've tried using the following code as well, but I have the same problem:
   DoCmd.RunCommand acCmdSelectRecord
   DoCmd.RunCommand acCmdCopy
   DoCmd.RunCommand acCmdPasteAppend
Does anyone know what causes a command to be unavailable?   I've had this same problem while trying to "undo" because there was nothing to undo, but that was easily remedied by putting a "If Me.Dirty" condition in.   What about selecting a record though; what could prevent a record from being selected?
Seth
