What steel to use for locating pins?
I am currently using 1144 steel heat treated to 50Rc for locating pins which are used on a fixture to build seats. When a seat is built a robot picks the seat from the fixture, there must be some binding happening between the locating pin and the part that sits on it. This causes the locating pins to break off at the undercut. The robot program has been modified to reduce binding but every few days a pin breaks at random. I am considering replacing these pins with ones made from a less brittle steel...any recommendations? Hopefully this will reduce the pins breaking.
RE: What steel to use for locating pins?
Mike Halloran
Pembroke Pines, FL, USA
Mike Halloran
