Selecting Double or Triple Geometric Constraints
Hi NX Users,
  While in sketcher & applying geometric contraints, is there a way to select 2 or 3 types of constraints at the same time?
  For example - Having a line go to the mid-point of another line.  I would want point on curve & mid-point.  Is there a way to select at the same time, rather than having to go through the motions twice to get this result?
RE: Selecting Double or Triple Geometric Constraints
Yes, just hold-down the 'Ctrl' key while selecting the curves/points which you would like to apply more than one constraint to.  In that way, after you select a constraint, the dialog bar will remain open allowing you to make multiple assignments before continuing.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Hi John,
  I knew there was a way.  I was attempting to hold the CTRL, SHIFT or ALT while selecting the contraint options.  It appears that I need to be holding the CTRL while selecting the line & arc entities instead.
Thanks again....
