Location tolerance of a hole at MMC with varying size dia's
I have a simple 13mm plate with a thru hole of 25mm +/- 0.5 and a location tolerance of 1 mm at MMC.
On one side of the plate the actual hole measures 24.5 allowing a 1 mm tol zone. The other side measures 25.5 allowing for a 2 mm tol zone.
What determines the bonus tolerance size considering varying measured hole sizes (within size limits) thru the part?
Does the smallest diameter measured dictate the bonus tolerance?
RE: Location tolerance of a hole at MMC with varying size dia's
John-Paul Belanger
Geometric Learning Systems
The bonus tolerance available due to the MMC modifier is based on the actual mating size (ref. para 1.3.26 & 1.3.11), which for an internal hole is the largest perfect form cylinder which would just fit into the hole contacting at the highest points.
In short: yes, the smallest diameter dictates your available bonus tolerance in this case.
