Churhill equation for bitumen froth
I am trying to size bitumen froth lines and I am wondering if I can use churchill's eqn for circular pipes. If not does anyone know what equation to use?
RE: Churhill equation for bitumen froth
Well I can't say that I've used it for that.  Foam flows can get a bit tricky as technically they are 2-phase and they may not be newtonian either.  The viscosity of the gas is not equal to the viscosity of the liquid.  Sounds iffy at best.
Do you mean the Churchill/Thelen equation to determine the Nusselt no.? Or just "No sports, whisky and cigars"?
