ODB history output for a specific instance
Hi I am currently working on convergence plots to determine the appropriate mesh density for a model with two part instances. I am plotting quantities such as ALLSE and ALLIE at specific time points to determine mesh convergence, but at the moment I can only output these quantities for the whole model.
Is it possible to output them for just one of the part instances instead?
RE: ODB history output for a specific instance
Yes, you can create a set of the surfaces or model of your choice and then create a history output and select just this set.
