36V to 5V step down converter__good in light load
this is my step-down converter:
..it is for ...
Vin = 36V
Vout = 5V
Pout = 1.67W Max
SCHEMATIC:
http://i55.tinypic.com/28lwh9s.jpg
It must go into skip-cycle in light load, hence the comparator.
It has a lot of components, but i see no cheaper way of doing this...since i need a good efficiency in light load, and a controller with low operating current.
I found some Buck IC's but they had high internal FET current limits
and so they would have high "staircase" current at start-up and POTENTIALLY blow the 500mA fuse which lies ahead of the above circuti on the 36V rail.
-Also, the Buck IC's were extremely expensive, and most dod not have pulse-skipping in light load.
by the way here is the LTSpice simulation file:-
ht tp://www.2 shared.com /file/yKEn T4cl/5V_SE PIC__with_ tripler_bi as_FO.html
do you know of a cheaper way?
..it is for ...
Vin = 36V
Vout = 5V
Pout = 1.67W Max
SCHEMATIC:
ht
