Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your information in this site is absolutely WONDERFUL. It is the most useful site on the web to me right now. Thank You Thank You..."
Geography
Pump selection for membrane filtration
EngSanM (Bioengineer)
24 Nov 10 11:22
I need to select the right pump for my filtration systems (MF, UF and NF), but I ignore the relation between the permeate flow rate desired and the feed flow rate needed.
Also it would help to know the feed flow distribution: what percentaje of the feed goes to the permeate and which one goes to the retentate.
Thanks.
Lan123 (Civil/Environmental)
2 Jan 11 20:53
Did you find the answer to this question? The membrane manufacturer/or the pilot runs should tell you what the operating conditions should be (ex. maximum possible recovery that will prolong fouling/scaling, transmembrane pressure) and you will have to size the pump accordingly.
biochemicaleng2006 (Bioengineer)
10 Jan 11 11:34
hi, you could using joky pump and put backfeed branch after pump  to control feeding to membrane
Close Box
Join Eng-Tips® Today!
Join Us             Close
