Basement/Retaining Wall Surcharge
Hey all!
Is it common practice to design with a construction surcharge behind cantiliver retaining walls and basement walls (restrained by floor at top)? I have been running the AASHTO 250 psf load but it increases the dimensions of the wall considerably on taller walls. If you use a construction surcharge, what loading do you use and do you have any code sources to back it up? Any info would be greatly appreciated.
RE: Basement/Retaining Wall Surcharge
