mildew in ICW installations
I'm about to build an ICW project.  Have you heard of any mildew problems between the foam and concrete wall?
RE: mildew in ICW installations
Does not happen, unless you have a very, very high humidity problem in your home, at which time it will form on the finish surface first.
