Visualizing Heat-Expansion
Hello!
I have following problem: I simulated the temp. behavior of a satellite (time dependent). Now I want to visualize also the expansion/deformation due to temp-differences.
Therefore I defined for my material also expansion coefficient. But I do not succeed in showing any displacement/expansion.
Which variables do I have to use for fieldoutput? COORD,MOT?
I was now searching for an hour here and with google, but did not find a solution for this perhaps to simple problem.
Thank you a lot for your help. Without, I did not get that far
RE: Visualizing Heat-Expansion
Tata
Tata
That far it also works, problem: The expansion is 0 for 0 Kelvin, but not for my reference Temperatur (given in Material constants).
Normally the movement of the nodes should be 0 for my reference value I thought?
Thanks till so far!
