Copying a complete model database to another abaqus cae window
Hello all,
Does anyone know anyway of copying a model from the cae window to another abaqus file? Everything I run an analysis from cae, abaqus just shuts down with no error message or reason I can see. I was going to try moving the whole database to a new file and try again.
I think the problem may have started from moving my .cae file from one network drive to another.
Thanks in advanced.
Thanks in advanced.
RE: Copying a complete model database to another abaqus cae window
I've had a similar experience myself and unfortunately was not able to resolve it and had to resort to starting over on my model. Some things you may try:
- make sure you go to the assembly module and click on Feature-Regenerate.
- instead of submitting your job through CAE, write out an input file first and then submit the input file to the solver using the Abaqus Command Prompt.
Hope this helps,
-CM
