using Abaqus python from ABAQUS command line
Hello all,
I am new to scripting. I am trying to get the data along a path and I tried the explanation in
http://www .eng-tips. com/viewth read.cfm?q id=154627& amp;page=1
The problem is in command line python does not recognize the "session" and gives me the following error:
name 'session' is not defined.
but if I copy and paste the same script in the abaqus cae then I would not get this error. I think one reason might be that we can not use "import visualization" in CLI. Is there any substitute for visualization?
Can you please help me and let me know if there is a way to fix that in CLI.
http://www
RE: using Abaqus python from ABAQUS command line
I am running ABAQUS python from the ABAQUS cmd, and it give me the above error. If I run this from CAE I won't get the error.
Are you suggesting that I can not use ABAQUS PYTHON from ABAQUS cmd?
