1/2" PLATE vs PLATE, 1/2"
I hope this is the right forum for this question. My company is in the middle of a debate as to the proper way to call out material. Some engineers have asked for the 'PLATE, 1/2"' or 'TUBE, 4" X 2" X 1/4"' style, while others want the size located before the shape...
To my knowledge, there is no standard, but what is more common?
Thanks in advance for your input!
John
John
RE: 1/2" PLATE vs PLATE, 1/2"
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
For what it's worth our company spec calls out noun, adjective(s) order explicitly.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
http:
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Thanks!
Plus non mandatory Appendix C if you so choose.
Also, putting the size (adj) before the name (noun) of the part doesn't make a lot of sense from an engineering perspective. 1/2" could be fore tubes, screws, plate, bar, etc.
Matt Lorono
Lorono's SolidWorks Resources & SolidWorks Legion
Matt Lorono
<Material Spec>, <Size> STK THK (<Descriptive Name>)
For example,
AMS5599, 1/2" STK THK (INCONEL 718)
The descriptive name is optional, but helps avoid confusion.
As for not specifying stock material thicknesses for machined parts, I believe that this is the best practice. The manufacturer (being knowledgeable about manufacturing) may wish to use a particular size of stock material for reasons important to the machining process, but unimportant to the functionality of the part.
STEEL, 1/2" STK THK, AMS5599
I am a Standards violator, myself. I dislike ALL CAPS and would go with:
Steel, 1/2" Stk Thk, AMS5599
I've seen many drawings that only specify CRES or 300 SERIES SS, but if you're dealing with production parts, consistency matters; you want to be darn sure about your material properties if you're making 100,000 widgets. Hence, if I'm checking a drawing, the material spec should be on there (at very least).
MATERIAL: 5052-H32 AL PER UNS A95052.
We don't have raw material in house, so I don't know how that would apply to naming a stock as its own item (standard first vs. general name and then standard)
Matt Lorono
