Spreadsheet opens but is not visible
Help!!!
I did something I can't find my way out of.
I wrote this code in a subroutine
sub delete_embedded_chart()
    Sheets("ChartMaster").Select
    ActiveSheet.ChartObjects(1).Select
    ActiveChart.ChartArea.Select
    ActiveWindow.Visible = False
    Selection.Delete
end sub
My spreadsheet no longer displays.  When I open it, it seems to be hinding in memory somewhere.  I went into the VB Editor and I can see all the objects on the left.  If I right-click the "view object" is greyed out.
I have tried several things to make it display, but I don't know how to get it back.
Any ideas?
RE: Spreadsheet opens but is not visible
Panic over, I realized that the Excel Application was open so I tried looking on the Window menu, and yes, there is an unhide choice.
I feel foolish for panicing, and don't see a way to remove this post.
If you really want to remove it, just Red-Flag the initial post. Then, simply explain that it is not needed.
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
jtlearning,
Glad you solved your problem.  I noticed you were hiding the active window in your code.  If you still want to do this and subsequently restore it you could use something like the following.
Sub WindowShow()
Dim Wn As Window
  Set Wn = ActiveWindow
  Wn.Visible = False
'Do stuff here
  Wn.Visible = True
  Set Wn = Nothing
End Sub
You need to save a reference to the active window in order to re-set its visibility since it will no longer be the active window after it is hidden.
Hope this helps.
M. Smith
