Sequence number OR Component name method
Hi
I am working on a steel structure modeled with BEAM188. I am struggling right now at trying to get the stresses written in an output file. I don't know exactly which option to use cause I have been creating .txt file easily for displacement and attributes with the ETABLE command. But when I want to define the stresses, either by ETABLE,sxx, S,X ANSYS tells me S is not valid. I have tried ETABLE,strain,EPEL,DIR and still doens't give me anything.
If you have done something similar in the past, could you help me out!?
