ASME IX groove weld type
Can anyone explain me if a bevel edge is imperative for a groove weld type according ASME IX.
Applications : pipes groove weld with 0.5mm to 2.8mm thick
thanks in advance
thanks in advance
RE: ASME IX groove weld type
Your answear is available even if the material will be under pressure ?
Thanks "metengr"
So, if I use a square bevel for my groove weld WPQ.
Can I make a fillet weld without bevel (square)covered by this WPQ?
check t allowed in your procedure
clean the sharp edges is required.
Now, the groove has to be designed according to the welding process you intend to use.
For that so thin pipe, a square preparation will be OK.
