ASME BPVC Section III Appendix N: Miscellaneous Impulsive and Impactiv
Hi All,
I found the table of contents for the ASME BPVC Section III Appendix N on the ASME website and wanted to know if any material has been added to section N-1600 MISCELLANEOUS IMPULSIVE AND IMPACTIVE LOADS. I checked the 2003 edition of the code and it says "In the course of preparation." under this section. So I would appreciate if someone can let me know if any material has been added to this section in the subsequent editions of the code.
Thank you very much.
RE: ASME BPVC Section III Appendix N: Miscellaneous Impulsive and Impactiv
Bond700
I checked the 2010 version:  ASME BPVC, Division I, non-mandatory appendix N, Section N-1600.  The same words "In the course of preparation." are still there.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Thank you very much Patricia.
