3000 to 250 psi reducing valve?
Anybody know any pressure reducing valves from 3000psi to 200-300psi made out of 316SS?
RE: 3000 to 250 psi reducing valve?
Getting stainless won't be the problem.
I once bought a cavitation control valves fabricated from billet. Almost anything is possible.
Just curious, how do you know he's using scuba tanks? Good point about the stainless, at 3,000 psig I'd be nervous about Chloride Stress Cracking in sea water.
David
By industrial, I take it you mean cheaper? Most scuba equipment is more expensive and have a more flashy finish than their industrial grade counterparts.
You'd probably want to consider 304.
My billet example was 3000 psig brine from cavern development for injection into a disposal well with unknown drop. The valve was made by Cor-Val (Now T3 Energy) but Fisher sells Cavitrol trim for simila valve applications. Masoneilan, Valtek and others can also do this. Several cavitation control trims can handle such drop with a clean fluid.
http:
