AFT Fathom Question
AFT Fathom Question
Good Afternoon,
I was wondering if anyone would be able to explain how I would model a simple circuit (attached picture) to calculate split flow in AFT. I don't know which icon is used to drain water to atmosphere. Can I simplify this in AFT or do I have to include a pump and reservoir, etc?
Josh
Josh
RE: AFT Fathom Question
I use Stoner PLS.
The outlet of your pipes could be a pressure node with outlet pressure set at atmospheric pressure. Alternatively you could add a valve node and designate it as an "exit" valve or use the spray discharge.
