Utility level engergy storage solutions/new batteries, etc
I am trying to find resources or data regarding large energy storage. I originally posted in the battery section but notice there has been no activity in that forum for over a month so thought I might post a link in hopes of some feedback on my situation.
http:/ /eng-tips. com/viewth read.cfm?q id=286355& amp;page=1
http:/
RE: Utility level engergy storage solutions/new batteries, etc
We are primarily looking for solutions that we can innovate in our shop to reduce installation costs. level of automation or attention will also be a consideration. I am just having a heck of a time finding good forums and such for this stuff at an engineering level.
I realize there are several ways to sync power but using that energy will likely be very difficult. For instance, the air system would require a HUGE tank and would need to likely run a turbine system. overhead water storage also represents a huge financial investment.
Excuse me for being blunt (but it's Monday): You have to decide if you want to run a business or just sort of mess around with stuff. If you are set on this particular site, you'll have to live with the power available, pay for three-phase service, or put in a generator. Maybe you can run it on bio-diesel and use the waste heat for something useful.
This is why I was asking for more explanation regarding purpose, scale, voltage and current levels... at what point on the continuum between Everready and Three-Mile Island are we talking about?
250kVA is no small amount of power to source, even if only momentarily.
Honestly, there are no solutions that fit this requirement. Why do you think all industrial back-up solutions still involve a genset?
http:/
for example.
Rafiq Bulsara
http://www.srengineersct.com
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
You can even use the low grade waste heat to dry the wood.
I doubt that getting a suitable 3ph feed run in would be as costly as all this plant.
