aero formula sought for teathered inverted stable cone
I am looking for a formula that relates the aircraft velocity, bank angle(radius of turn), length of a teather, and weight of an object on that teather for a stable solution. Normally a teathered object in a turn will be forced outboard by the centrifical force, but there is an inverted stable cone configuration also, whereby the aircraft can fly in concentric circles with a payload on a teather remaining relatively stationary given the right combination of weight, length of teather, turn geometry and speed.
RE: aero formula sought for teathered inverted stable cone
