bushing material for aluminium shaft.
Hi
im designing parts for a motorcycle which is a rotating horizontal valve near the exhaust port on a two stroke motor.
the valve weights about 150 grams and is coupled to another valve in a cylinder parallel to it.
a servo motor cycles it between about 0 and 90 deg at about 3 rad/s.
the bushings are supporting both ends of the valve which has a lenght of about 120mm and has a bearing surface of 10mm each side.
the valves are made from high silicon casting aluminium 4xx series i believe.
im wondering if anyone has any suggestions as to whether sae 660 high leaded tin bronze or phosphor bronze would be best or how i could even calculate stress'es or wear on each type?
RE: bushing material for aluminium shaft.
Grease or oil lubricated??  Try www.ggbearings.com for advice on metal polymer plain bearings, they have lots of automotive applications similar to yours.
They are installed lubricated in two stroke oil and gets continuous lubrication from unburnt oil. btw the OEM bushings are a bronze graphite sintered type mix or atleast seem to be.
thanks for the link i shall have a look see if i can find some information.
Try DP4 material from GGB for example, from what I remember gives good performance under oil lubricated oscillating conditions.
