Heat transmission in WB
Hi guys, I'm trying to do thermal analysis with WB.
I have a resistance with a temperature range from 0 to 450°C.
Near the resistance I have a strirrup. It supports a thermostat. The thermostat clicks at 220 ° C.
I wanted to know, how long does the strirrup take (seconds) to bring the 220°C to the thermostat?
In this way, after I'd like to change the dimensions of the strirrup and to see how it affects on the distribution of heat.
thanks
RE: Heat transmission in WB
can someone help me...thanks
