Artificial Lift
Artificial Lift
Artificial Lift
Can someone suggest a book or a website which provides information regarding Pros & Cons of the different Artificial Lift methods
RE: Artificial Lift
alrdc.org
RE: Artificial Lift
I wrote an Oil & Gas journal a few years back that may help if you are talking about getting water off of gas wells.  You can find it at Deliquification vs. Artificial Lift .  I don't know how much it will help if you are artificially lifting oil wells.
David
RE: Artificial Lift
thank you
RE: Artificial Lift
For decades James Lea has authored/coauthored an annual article in O&G Journal (maybe also SPE Journal) on "new developments in lift".
RE: Artificial Lift
Dr. Lea's (along with Dr. Winkler) annual article is in World Oil, not Oil & Gas Journal.  Their book on Gas Well Deliquification from Gulf Press is pretty good too (I guess I can say that even though I wrote one of the chapters).
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
"It is always a poor idea to ask your Bridge Club for medical advice or a collection of geek engineers for legal advice"
RE: Artificial Lift
Page 10 of the attached weatherford brochure has a good summary of the different capabilites and pros and cons of different artificial lift systems.  the only thing is doesn't really mention is directional requirements (you don't really want to be putting any kind of rod driven pump at more than about 60° or with a maximum dog leg of more than about 5°/ 100ft - I've got the nightmares to proove it).  And there are some obvious things: gas lift needs a source of gas (I once spent a 4 well campaign installing gas lift completions into a onshore west african field producing undersaturated crude with no gas processing facilites nor gas import line..... utterly bonkers); jet pumps need a power fluid (unless you use produced fluids, but then your production rate is the difference of two big numbers and so not very accurate).
http://www.weatherford.com/weatherford/groups/web/documents/weatherfordcorp/003098.pdf
RE: Artificial Lift
I'm bored so I'll give you my experience.
1) Beam pumps are effective for shallow depths, straight holes and fluid rates of less than 500 bfpd.Above 500 bfpd rod wear, tubing wear and pump replacement will eat you alive.
2) Positive displacement pumps(KUDU/Moyno) are effective for high volumes and shallow depths(<3000'), but sucker rods are not designed for torsional loading, so if your supplier doesn't know how to space out properly when the rods are wound up like a rubber band and shrinks you'll have a fun fishing job.
3) Gas lift works in multiple enviroments and depths, but again is for high volume wells, otherwise you can't afford the hp requirements.
4)Submersible pumps are also for high volume lift, but are sensitive to power problems and sand.  If the hole is crooked you make kink the cable about 4 times trying to get it to bottom. I also don't like the fact that the moving parts are underground.
5) Jet pumps for high volumes lift are excellent and can handle some solids and can move more fluid per HP requirements. Power fluid is either water or oil, but they are not very effcient at low volumes. Also, be aware that there are jet pumps being sold that are not configured properly and are not as efficient as others.
