Timber concrete composite deck - natural frequency
Greetings!
I am designing a timber concrete composite (TCC) desk/floor - a thin concrete plate should be poured on existing timber beams, connected with TCC screws. The existing beams are parallel to each other and run in the x direction.
The static analysis was made on a T-section (a timber beam as the web, concrete plate as the flange - where the flange width is the distance between the beams). The design was made "by hand" according to Eurocode 2 and 5 taking the slip between the two surfaces into account. As a result I got the bending stiffness in the x direction (direction of the beams).
Now I would like to determine its first natural frequency with modal analysis - the standards require at least 8 Hz.
I wonder if the following model (in Sap2000) of the deck could give good results: frame objects with the bending stiffness of the T-sections are positioned in the x direction with appropriate restraints. Over them the thin concrete plate is placed – but for this area object the bending stiffness modifier in the x direction is set close to zero, say 0.01. In that way I hope, I get the bending stiffness in x directions as it was calculated by hand, and in y of the concrete plate.
I would be grateful for any comments or suggestions.
RE: Timber concrete composite deck - natural frequency
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
But maybe that the modifier is so low is simply an alternate statement of the difficulty of properly fastening the RC plate to the web, particularly because the thickness of the plate.
Anyway I don't think it necessarily impossible, just not cheap; quite likely a header plate heavily screwed to the web might work, and come with welded shear ties enough to pass the forces. This however may call for a thickness you are not considering to use, and full composite action even if mechanically ensured is not likely to be entirely attained.
How many TCC screws are required to ensure full composite action and what size timber are you using.
My recommendations would be the typical timber beam with plywood floor which can be used as a diaphragm.
h
