Solder joint at 120 degree C, any solder paste to recommend?
I'm looking for a type of solder paste which is tested and found pass under 120 deg C operating condition for long hours. Can any one shed some light here?
Best regards,
ct
RE: Solder joint at 120 degree C, any solder paste to recommend?
Dan - Owner
http://www.Hi-TecDesigns.com
www.MaguffinMicrowave.com
Maguffin Microwave wireless design consulting
Mike Halloran
Pembroke Pines, FL, USA
Best regards,
ct
Please let us know what you find out.. But yes a call to Indium or Kester would be a great place to start
TTFN
I would not want to use it in a structural application to hold any weight, as it will creep more at elevated temperatures. But for electronics, 60-40 has been used in military systems with storage requirements to 120C since Hector was a pup.
You might consider 63-37 tin lead solder, as it is a true eutectic solder mix, and elevated temperatures will not cause any of the metal to precipatate out (which might cause a cold solder joint over time).
But like someone said, talk to a solder company!
