Fluid Cat Cracker @ 1,400F - CrC HVOF embrittlement - Spray and Fuse
I learned the hard way that HVOF-Cr3C2 can embritteled when exposed to 1,400F. Embrittlement leads to hardness increase, crack propagation and coating failure.
Customer suggests to switch from HVOF-Cr3C2 to NiCrB Spray-and-Fuse (C88). Does somebody experienced SF C88 at 1,400F? Knowing hardness and galling resistance at this temperature could be a good start.
Any other coating suggestion for such an application?
Luxeal
RE: Fluid Cat Cracker @ 1,400F - CrC HVOF embrittlement - Spray and Fuse
hi hsbcn,
300 class - 50psi
Luxeal
