"K" values
"K" values
"K" values
Hi
In earlier version NX7.0 when I generate my NC program there will be  no "K" values like "G02Y-29.37 Z303.65 J0.0 K-1.273" but I can see "K" values in NX7.5 . If run my program is there any problem. If I want avoid "K" values so , what should I do. even I changed in def file ie there is option that   K  cooridinates "off" still I can see K coordinates.
*** sorry for my poor english
thanks
RE: "K" values
Is this for a helical move?  in the custom command PB_CMD_init_helix you can remove the K word.  The only other option would be to disable the K word from the word sequencing page.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6.0.5.3
