Engineering Properties - Peat
If a situation arises where a deposit of peat cannot be removed and a stability analysis is required for failure of any emabnkment with peat at the toe, what can one do to mimic the behaviour of the peat?
Also, I am curious to know if there are any published values for the undrained shear strength of peat? Also, if available, what is the common value(s) used in practise?
RE: Engineering Properties - Peat
Chris Bosy (312 922 1030).
I was involved some in researches on peat long time ago. Unfortunately, I do not have the publications about that with me now. Perhaps you can contact Prof. Budi Susilo Soepandji at the University of Indonesia. He definitely has results from the UU and CU tests on peats.
Just check www.ui.ac.id and contact Prof. Soepandji.
Agus
How high is your embankment? I know that we have left peat in place in a few tailings dams - at the toe, etc. with no problems. Agree that field vane tests are an appropriate initial method to look into. Also, you might consider a trial embankment if this is a major project. Remember, too, a stabilizing berm at the toe will also compress the peat and increase it's shear strength. Use of wick drains with stabilizing berms would surely help to speed up consolidation. Keep in mind though, that as peat consolidates, the coefficient of permeability decreases remarkably. I remember doing tests on Saskatchewan peats/muskegs that showed two to three orders of magnitude decrease in permeability coefficient under some 1500 psf load.
Hope this helps a bit. Best regards.
