6" PN 250 valve manufacturer wanted
Good day everybody,
We are looking for a 6" (DN 150) PN 250 ball valve for a test stand (pure water). Valve shall be electrically driven plus option manually actuated. EN or ANSI flange doesn't matter. Does somebody know a reputable manufacturer? It shall be a ball valve (full ball or half sphere). Thanks in advance!
regards
micalbrch
regards
micalbrch
RE: 6" PN 250 valve manufacturer wanted
Above on the presumtion that water shall pass through the valve at some (higher pressure).
This will open the range of suppliers.
is the valve fitted with a martyr valve as a bypass if not i recommend doing so, or changing the valve type
Their is also a website where you can check which suppliers recently supplies what you are looking for. the website is
http://www.shipserv.com , hope this helps!
