Siemens Sinumerik Post Builder Controller Change Help
I'm using the UG Siemens PostBuilder, and when I started making a 2 axis Lathe Post, I picked the Controller as a Sinumerik 840D Lathe.  What I found out today was the controller is actually a Fanuc controller.
Is there anyway to easily changed this over? Or to change the nurbs so it runs correctly?
--BuckShott00
RE: Siemens Sinumerik Post Builder Controller Change Help
I recommend you start over, and select a Fanuc controller when you create the post.
Mark Rief
Product Manager
Siemens PLM
As Mark said, just start over. That said just open the current one and the new one with the proper control side-by-side. Makes it easy to re-populate all the information. You are not the first to have to do this... and won't be the last. It goes pretty fast that way.
Bill
Thanks you two.  I'm new to post-writing, and it took me a while to get this one "right" so to get all the way done and find out that I messed up one of the fundamental pieces was pretty hard to swallow.
