Frequency issue
Frequency issue
Frequency issue
hello, i'm a newbie here.
My country use 50Hz supply voltage. Some machine arrives and require a 60Hz supply voltage. so i plan to install frequency inverter.
From my understanding, frequency inverter use PWM and motor can run w/o any problem with modulated signal. so my question is can other equipment (relay,transformer) work well with the modulated signal?
please advise.
Rgds
milimiter
