Flakey Streamline Operation
I keep getting the error message...... "The Flow and Cross curves do not intersect within tolerance. Select intersecting curves." ......in a pretty simple streamline operation.
I have checked and rechecked the endpoints of each and every flow and cross curve I have, and the distance between them is always zero, out to nine decimal places. I HAVE INTERSECTING CURVES.
Where is this wonderful "intersect tolerance", and why is it stopping me from completing this Streamline operation?
Hint: I get no cut direction indicators when I ask for them, either.
The error message says "do not intersect within tolerance". Changing the chaining tolerance has not affected this broken operation.
What is "intersection tolerance"?
I replaced the cross curves (splines) with lines connecting the flow curves, checked each intersection to make sure I have a perfect intersection (distance is ZERO between endpoints...). Now, the operation HANGS!
IR 6438738
Proud Member of the Reality-Based Community..
RE: Flakey Streamline Operation
How many flow/cross curves do you have? If you have a 4 sided patch with more than 2 flow curves (or more than 2 cross curves) they will have to touch (within tolerance) at each intersection, not just end points.
Thanks for the reply, cowski.
Two flow curves, two cross curves.
I still have not found out what "intersection tolerance" is.
Could you provide the part file for us?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
