Sheet metal bug? SW2011 SP0
I have had a bug with the sheet metal feature of SW2011, SP0.
I usually create sheet metal parts for door frames then do a 45° cut in the corners to create a mitre. When solidowkrs notices the 45° cut intersecting a faces normal to the sketch plane it jogs the cut, however for some reason it no longer jogs it and creates a straight cut line and bogus cut file.
How do I fix this, I need to know quite urgently as my bos wants the flat pattern files by the end of the day :S
RE: Sheet metal bug? SW2011 SP0
Ok, I have found the solution and feel like a bit of a jerk. I had to heve the 'normal cut' button checked in the cut extrude. OOps :)
I didn't open your file but you could extrude as a surface body, trim and then thicken.
Tried to open but reports "future version"
To me it is early yet to be using 2011, or am I just slower that everyone else?
Hardie "Crashj" Johnson
SW 2010 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
Not necessarily slower ... just more cautious.
Or in my case lazier
just say no to SP0
