Strange behavior
Strange behavior
Strange behavior
Has anyone seen Imagware do this? Do you know how to work around it? When make used defined cloud cross sections I lay out the cross sections I want. The cross sections are not made where I drew the lines on the screen. It looks like they were shrunk down 75%.  I have had the same problem with circle select points on the same file.
RE: Strange behavior
This is just a guess but delete any .vr files and repeat the instalation. There might be a .surftool.vr in your root directory.
I found out how to prevent this from happening.
I happens when an enviroment is mapped. Like steel or ramp. So just turn off the enviroment map before doing any operations.
