what name of the pump?
Good day sir.
I got the problem with my PUMP. I don't know the name of manufacture or model code of the pump. But I am sure this is the piston axis pump, diameter of piston maybe 25 mm.the number of piston are 9. The inlet port is larger than outlet port. The rotation of pump is clockwise.
The swash plate is control by mean of hydarulic, but I don't know how exact it does. And the situation is:
At first, the pump done well
After, when the pressure is about 50 bar, oil has gone to tank by drain line.not go in the outlet line of the pump. So the pressure gradual decrease.
Please help me to tell the name, code of the pump.And what problem with my pump. Thanks you very much.
RE: what name of the pump?
If you are sure that the flow (full flow) is going back to the tank when the pumps exceeds 50 bars, it will be either the pressure relief valve that is set to 50 bar or - as ash9144 suggests - the piston rings are worn.
What brand your pump is? I have absolutely no clue. But companies like Parker, Vickers and Rexroth manufacture such kind of pumps. If you have a distributor of those nearby, ask them for help.
And some particulars regarding what it is connected to or what drives it.
Information is not a bad thing.
rmw
I see the orther pump, but they are the same kind. and i have some information:
- i see on the house of pump the word " MUUUFK 8J3887-2-" and "UNNROU"
- This is picture of the pump
Thanks for reading.
please tell me any information you know a bout this pump.
