How to get the Hard Drive Serial Number given by the Manufacturer with
How to get the Hard Drive Serial Number given by the Manufacturer with VBA?
Please note that I need Number given by Manufacturer & not Hard drive serial number which is a random number that is generated by DOS or Windows every time you format your hard drive.
RE: How to get the Hard Drive Serial Number given by the Manufacturer with
You might check at Tek-Tips.com - a sister site to this one and it is where the computer geeks live.
Check with the hard drive manufacturer. Most of them have tools for that.
Double posting is NOT a good idea and is confusing!!
There is some code buried in the discussion here:
http://thedailyreviewer.com/office/view/programmatically-obtain-the-hard-disks-serial-number-from-vba-101853101
I have re-written it to work as an Excel UDF:
CODE
Function GetPhysicalSerial() As Variant
Dim obj As Object
Dim WMI As Object
Dim SNList() As String, i As Long, Count As Long
Set WMI = GetObject("WinMgmts:")
For Each obj In WMI.InstancesOf("Win32_PhysicalMedia")
If obj.SerialNumber <> "" Then Count = Count + 1
Next
ReDim SNList(1 To Count, 1 To 1)
i = 1
 SNList(i, 1) = obj.SerialNumber
i = i + 1
If i > Count Then Exit For
Next
GetPhysicalSerial = SNList
End Function
Paste into a VB code module, then enter =GetPhysicalSerial() anywhere on a worksheet.  If you have more than one physical hard drive enter as an array function to return the serial number for each drive.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
What other information we can get from WinMgmts: ?
I can't help there at the moment.  I have never seen this object before, and I don't recall reading about it in any book I have.  I can only suggest following up the links in the discussion I linked to in my previous post.  If I have time to do some research myself I will post something on my blog, but I don't know when that will be.
Doug Jenkins
