Butterfly valve question
Hello all you Guys,
probably a obvious question, but i'm not too familiar with this field, so be gentle.
Does a (butterfly)valve body need to be a "one-piece" item, or may it be bolted/welded together from separate parts?
Thank you all kindly.
RE: Butterfly valve question
Some butterfly valves have seat retainer plates which, one could argue, may be a split body pattern.
- Steve Perry
http://www.linkedin.com/in/stevenhperry
This post is designed to provide accurate and authoritative information in regard to the subject matter covered. It is offered with the understanding that the author is not engaged in rendering engineering or other professional service. If you need help, get help, and PAY FOR IT.
