Things I'd like to see in Draft
Just doing some drawings in ST2 and there are some changes I'd like to see to make things a bit easier - mainly from the drawing view Options menu.
1. A use (not before time) for the Description text - why can't this be added below the view name/scale text with its own text size.
2. Set the 'Rotation angle' from the Edge bar, as you can for scale.
3. Toggle drawing view border on/off from the edge bar.
4. Toggle broken-out section view profiles on/off from edge bar
5. Select/check/match configuration available in edge bar.
Having to go into view properties takes quite a long time for big assemblies, and should not be necessary for the above options.
Could we also please get rid of the value box that comes up when you click a dimension - I can't see the point in draft and it just takes the focus. It doesn't do it in traditional part sketches so why in draft?
Have any of these things changed with ST3?
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
RE: Things I'd like to see in Draft
bc.
Quadro FX4600.
That applies to model views.
Saved view configurations can be any orientation.
It would be nice to be able to change an existing view orientation instead of having to create a new one.
I just had to turn a big assembly model through 90° to get it in the correct orentation and it completely screwed up the drawing I'd started.
bc.
Quadro FX4600.
bc.
Quadro FX4600.
bc.
Quadro FX4600.
