Find Bodies with Material Applied inside a Product
Hi everyone,
I have a CATProduct and I need to select all the Bodies which have a material applied. I know there are some queries by the search command in order to filter the searchs, but I dont know how to achieve my goal with this query.
What I was doing first, was to select all the Bodies within the Product with the next command
Selection.Search "'Part Design'.Body;all"
And then I am checking each Body at a time to know if there is any material applied.
Set Body = Selection.Item(k).Value
TheMaterialManager.GetMaterialOnBody Body, TheMaterial
Density =TheMaterial.AnalysisMaterial.GetValue("SAMDensity")
if there is no material applied i will get an error by reading the density so with this Err.Number<>0 I know there is no material.
I know my solution is not very elegant, so I am trying to find another method with a query or something
Do you guys know any other way to do this with a query or other method?
Thanks in Advance
RE: Find Bodies with Material Applied inside a Product
If you want to select only those bodies which doesn't have any material assigned you can use (in CATScript)
Language="VBSCRIPT"
Sub CATMain()
CATIA.StartCommand("Collapse all")
Dim productDocument1 As Document
Set productDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = productDocument1.Selection
selection1.Search "NameInGraph=*Material=None*,all"
End Sub
Fernando
cadromania.net - Romanian CAD forums
Update...
The script above is not so good if you don't have any material applied...in this case I suggest to check the density of each part, usually if you don't have any material, CATIA will apply by default density of 1000.
Language="VBSCRIPT"
Sub CATMain()
Dim partDoc As Document
Set partDoc = productDocument1.Part
Dim partRoot As Document
Set partRoot = productDocument1.Part
 MsgBox "The density is " & partRoot.Density
End Sub
Fernando
Thanks for your help,
what I am doing is to check like ferdo said the density, but in my case the density of all bodies. Because in a Part I could have diferent bodies and maybe one doesnt have any material applied and the density of the Part wouldnt be 1000 (not uniform).
this is the code
Set Inertias = TheSPAWorkbench.Inertias
Selection.Search"'Part Design'.Body;all"
for k = 1 to Selection.Count
Set inertia = Inertias.Add (Body)
if Inertia.Density <> 1000 Then
MsgBox(Body.Name & " Doesnt have any materlial properties")
End If
Next
So, you want in fact something like this, isn't it?
Sub CATMain()
Dim TheSPAWorkbench As Workbench
Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench")
Set Document = CATIA.ActiveDocument
Dim Selection1 As Selection
Set selection1 = Document.Selection
selection1.Search "Name=*body*,all" 'Or "CATPrtSearch.BodyFeature,all" if you want only PartBody
for k = 1 to Selection1.Count
Set Body = Selection1.Item(k).Value
MsgBox Selection1.Item(k).LeafProduct.Name
MsgBox(Body.Name & " Has material properties")
Else
MsgBox Body.Name & "Has NO MATERIAL properties", vbInformation, "NO MATERIAL"
End If
Next
End Sub
Fernando
